My abs light and my check engine light stay on. I have heard of "pulling codes" for both the ecu and the abs unit. How do you do this for a 95 integra?
have you put new brakes on this car? It may just need that. Check those and if they have more than half pad left on them then let me know. I believe you have to ground a wire on that model and the check engine light will blink indicating your "trouble code". I'll check tomorrow on my integra
over by the ecu there is a 2 wire connector I believe its brown and another color...all you need to do is stick a jumper in there and click the key to on and count the big a little flashes
