How Do I Fix This?
Discussion in 'General Tech and Maintenance' started by GSRCRXsi, Mar 1, 2003.
  1. GSRCRXsi
    MD
    ok just a few mins ago i was installing my type r valve cover seen below. nice huh? (excuse the slight discoloration, its just my shitty digi cam)
    my engine
    (hah i remember when i first came here and B told me to get a real intake i had to modify an AEM one, lol)
    but theres one prob, while tightening it down i snapped one of the bolts. broken bolt
    now how can i fix this?, can i replace to bolt? where can i get one? should i be worried about the valve cover being not sealed enough? i appreciate it. thanks.
  2. Darivative
    Darivative Guest
    Just replace to stud...
  3. GSRCRXsi
    MD
    is it hard to replace? and where can i get one?
  4. onefastcivic
    onefastcivic Senior Member
    i dont know how to get it out (prolly just tap it out)but you can get a replacment from honda
  5. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    Yea, call your local Honda dealeship and buy a better torque wrench. Have fun tryin to get that stud out though.
  6. GSRCRXsi
    MD
    how much do you guys think honda would chage me to replace that one stud? throw some numbers at me. should i be worried about it leaking?
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Damn,how hard did you torque it?Just pull off the valve cover and get some vise grips,clamp it and unscrew.Go to Honda and get a new one.The seal should be good enough,but you may get some light leakage.Make sure the others are tight,and don't drive it to long like that.They shouldn't charge you more than a buck for a bolt that small.I got all 16 bolts for my tranny shipped for $15.
  8. GSRCRXsi
    MD
    i didnt even torque it. i dont have a torque wrench. i was using a small little socket wrench. i just wanted it to be tight, bc they were pretty hard to get off. but i wanted to know how much honda would charge me to replace the bolt for me. thanks for everyones help so far.
  9. xj0hnx
    C.C.TX.
    Hard to say how much they would charge.They may just look at it roll their eyes,pull it out and replace it.Or they could break out their "it's gonna cost ya labor fees"
  10. Darivative
    Darivative Guest
    Snap on sells a tool to remove studs from the block. Just do it yourself, because a shop is gonna rip ya...
  11. TRuggiero_
    Winter Garbage, Fl
    Just call and get a quote. People do it all the time. And by the way, buy a torque wrench, a good one.
  12. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    do it yourself. i snapped one before.. it was really easy to do.
  13. GSRCRXsi
    MD
    pills what exactly do you do?
  14. GSRCRXsi
    MD
    pills i tried to send you a PM for instructions on how to replace that bolt, but your inbox is full. sent me a PM or email on how to do this please. thanks.
  15. Darivative
    Darivative Guest
    It's really simple...Just purchase a stud remover and then remove the stud, afterwards put a new stud on and your done! Snap on sells this for a reasonable price...
  16. GSRCRXsi
    MD
    i get the feeling it screws on. like its threaded on both ends. but its just a hunch, unless someone knows for sure that its not.
  17. draztik impulz
    draztik impulz Junior Member
    i know a way to get the bolt out. get a drill bit one smaller than the bolt obviously and drill in the middle of the bolt then get a screw hammer it in then unscrew the screw. its just that easy trust me it works done it many times on different screws and bolts
  18. pills_PMD
    New Albany, OH
    either what was posted above... or borrow a stud remover.
  19. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    snap on makes a tool called an easy out it a rverse drill bitt that you use a wrent to tighten and as it tightens it spins the stud out it cost like 5 bucks and has worked a shit load of times now
  20. solblu
    solblu Senior Member
    Ricer
    You don't need any special tool. It's got a 10 mm "nut" on the bottom. Go to a junk yard and steal one and put it on your car. It will take you 5 minutes. If you are too good for getting it from a junkyard go to your Honda dealer and get one. They are $3.44 at majestic and list for $4.62
