what's wrong with that set up? wrong intake? different battery?Put a piece of rubber between your intake and positive battery terminal, right now! You don't want that to arc.
thank you blanco you are d man.5 is MAP and 8 is TDC. https://hondaswap.com/reference-materials/88-ecu-error-codes-29109/
The best way to hear or check for VTEC crossover is to remove the air filter and its housing temporarily. You should be able to hear it with these items removed. At least, that's what works for me and other people I know. I hope this helps!
What does it sounds like?
