How do i read my P28 ecu codes?
Discussion in 'ECU's, Electronics, and Tuning' started by fakk_13, Oct 20, 2006.
  1. fakk_13
    fakk_13 92GSRB17
    Oak Town, WA
    i have a 92 Gsr with a b16 and a p28 mugen chipped ecu. my check engine light turns on every now and then. so i tryed to read codes but i cant find a light on my ecu. What do i do?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its not on the ecu you got to count the blinks that the check engine light makes
  3. fakk_13
    fakk_13 92GSRB17
    Oak Town, WA
    Ive looked on the web and i cant find a place that tells me how to check it other than a couple sites talking about blinking lights
  4. AHHVTEC
    Alabama
    on the pasenger sid of the car there is a 2 wire blu plug jump a wire between the terminals and count the check enigine light as it blinks it will be fast and long pulses.
  5. banks88
    banks88 New Member
    i have a 89 dx that has a z6 motor swap in and a p28 cpu but the morons that wired it did not wire the plug (serviec check connecter)[​IMG] to jump the wire, so i was wondering if any body knew what the pin out on the p28 are for this connecter??? much help aprecited h
  6. djfaded1
    djfaded1 New Member
    Does anybody know what an error code 36 is on a Jdm H22 automatic vtec engine with p13 ecu. Done some research but nothing and also I had my 93 accord tcu running with p13 ecu do i need the P19 tcu insted of my stock system and is it hard to hook it up...thanx faded 1
  7. reikoshea
    Dallas, TX
    not the place for this but code 36 is a traction control code. usually it doesnt display unless there is another code.
  8. djfaded1
    djfaded1 New Member
    Hey thanx for the help its just ive been trying to find some info do you know what I need to do to fix that problem with the engine code 36 thanx
  9. reikoshea
    Dallas, TX
    post in a new thread dude.
    the way to fix 36 is fix the other codes.
