How do shocks work?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Canuck 93 Civic Si, May 5, 2004.
  1. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Does anyone know a good page with a good illustration about how variable rate shock dampening works? Ive looked all over and cant seem to find anything good.
    Thanks
    Sean
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    howstuffworks.com
  3. Canuck 93 Civic Si
    I checked there first, they had nothing.
  4. tab
    tab Super Moderator
    Aberdeen, Washington State
    Springs and valves work together to control a fluid dampening of motion. IE, fluid pressure slows down the motion. Like trying to clap your hands under water. That's pretty a simple explanation. :)
    Oh, as for the Variable part. Some of the illustrations that I have seen are still pretty simple. A sudden rise in pressure(a sharp bump) causes a valve to close, slowing down the fluid transfer rate, thereby slowing down the upward motion of your tire. When the pressure drops, the valve is allowed to once again open. This is a good design, because it allows the shock to absorb more impact when needed, and yet provide a decent ride when the road is not so bumpy.
    Remeber that the dampening effect has nothing to do with spring preload, suspension travel, or the spring rate.
  5. Canuck 93 Civic Si
    By variable dampening, i mean that you can adjust the dampening rate with a knob or dial like Tein or Konis.
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  7. jdmvteccrx
    jdmvteccrx Member
    good question i have been tryin to figure out how a shock works for years!
