how do u....
Discussion in 'General Tech and Maintenance' started by CRX2NR18, May 9, 2004.
  1. CRX2NR18
    CRX2NR18 Senior Member
    how do u know if a throw out bearing is bad? i took my tranny out yesterday and i pushed it and it came out fine and it still spins really well but when i drove it i heard a vibration in the tranny... like a crrrrrrrrrrrrrrrr noise... bad bearing?
  2. 4DRonDUBS
    4DRonDUBS Senior Member
    if the trans is in the car running at idle speed you can hear the bearing chatter and then when you would push the clutch in its gone..
  3. CRX2NR18
    what would make that noise when im going through my gears? shaft on tranny is fine too
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    maybe worn syncros
  5. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Does your tranny whine with a pitch that inceases in frequency (gets higher pitched) with increased RPMs? If so, then your syncoros are going bad.
  6. CRX2NR18
    no its more of a grinding noise, and it goes away sometimes too, but its really loud when im in 1st or 2nd gear...
  7. CRX2NR18
    what about when its out of the car, it spins fine , what else could cause my tranny to grind at like 2400 to 4000rpm
  8. Citizen_Insane
    Minneapolis
    Do you have an LSD Tranny?
  9. CRX2NR18
    no, its just an SI tranny
  10. JDMG2i
    JDMG2i Junior Member
    It could just be your axels I but a JDM type R motor in my freind 4 door integra and the whole front of his car would shake until I changed the axels
