how do you know when vtec kicks in?
Discussion in 'General Tech and Maintenance' started by 1996cool, Jun 9, 2005.
  1. 1996cool
    1996cool Junior Member
    I have acivic 1996 dx and did a mini on it vtec .the thing is that I dont know if its kicking in. what am i soposed to feel if any thing and also will dx ziggy fit the vtec head
  2. brian11to1
    brian11to1 Senior Member
    you have a dx with a y8 head? vtec engagement isnt as noticable on sohcs as it is in dohcs.
  3. 1996cool
    ok, so what about the ziggy is it the same do you know? just wondering ....how can i make my car a little faster ? what about cams are they good investment copared to $ verses the difference
  4. sohcslammer
    sohcslammer Senior Member
    Bay Area
    This is what it feels like....
  5. brian11to1
    thanks for adding nothing...
  6. formby
    formby learning in progress
    he did its called humor.... any who, a dry shoty is the cheapest way to add a good kick....
  7. pissedoffsol
    ziggy. wtf? ziggy marley is on your car?
  8. adnoh
    adnoh Senior Member
    Ontario
    I think he means Dizzy
  9. formby
  10. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Its hard to tell if vtec has "kicked in" in a sohc, as i can barely hear it on my ex, all i have is a v2 intake, but in a dohc w/ just an intake you can easily hear it open up and "kick in".
  11. jdmeg6
    jdmeg6 Senior Member
    So Cal
    :werd: SOHC's dont exactly scream or pull hard like a DOHC does when VTEC is engaged, so you might not even be able to tell unless you have some mods.
  12. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    going onto a entrance ramp in third gear with the radio off, you should be able to here VTEC kick in (assuming you don't have a gay fart can muffler) The exhaust note should change just slightly if you slowly make your way up to speed.
    How to make it faster? Buy a d16a6 block, put some zc pistons in there, better cam, and tune it like crazy.
  13. spectacle
    spectacle Senior Member
    St. Petersburg, Fl
    :lmao:
  14. jamesA
    haha I was watching that one day at work... when that scene showed I just busted out laughing. :lol:
    You won't really feel or hear SOHC Vtec kick in. It's too subtle, but my only SOHC experience is in my buddies car and there was a loud fart cannon already on it when he bought it.
    You will hear the B16 VTEC even with the stock intake on it. With a CAI or SRI you will hear it very very well.
  15. HollowJDM
    HollowJDM Senior Member
    oooohh, dry shots make me cringe. yes, cheap and power, but unless you have a good significant way to increase your fuel, ouch. talk about lean. wet shots are safer in my opinion, they add the needed fuel to match. ive found on many other forums that best thing to do said by many people is to just turbo the motor off the bat, can safely hold 8 pounds without motor built. people tell me its the only way to get noticeable difference (keep in mind i have no personal experience with that so nothing to back it up)
