Like the title says, I want to remove the Top Speed Limiter on my Accord. The damn thing tops out at 111. I'd like to go a bit faster then that! Anyone know how to remove it?
carefully open your ecu with a philips head screwdriver...
you can manually remove your top speed limiter and rev limiter by using a jewelers screwdriver to pop the chip out. it's a little black chip with white writing on it. it says something like "tsl/rl". just be careful and take your time. it's pretty easy. i did it on my civic si.
Where the hell can you possibly do more than 111 safely? Stop putting yourself and others in danger. (if you are planning to do this on a track i take that back)
The info about removing the chip was wrong! There's no such thing on that ECU's circuit board. Instead I hooked up a toggle switch to the vss. This way when I get to 105 or so, I can toggle the speed signal off and it won't hit the limiter.
I realize that, I've been to the city a bunch of times. That's why I posted the vid to clear things up a lil. Where I'm at, there's a ton of roads that look like that, hence the 100+ MPH.
