How hot
Discussion in 'General Tech and Maintenance' started by sk8er602, Aug 14, 2005.
  1. sk8er602
    sk8er602 Senior Member
    Athens, Ga
    How hot will my factory exhaust manifold get, is there any kind of glue or expoy that can deal with that high of heat.
    I need to know b/c my o2 sensors threads came off and dont fell like droping a 100+ on a new one
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    weld it!
  3. SlushboxTeggy
    NJ to MA to CA
    1200F, i believe.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Real fucking hot :) Just weld it back in.
  5. B16CRX
    B16CRX Senior Member
    Greenville, SC
    no glue or epoxy can take that. at least not the kind of crap you can buy over the counter. It's not that hard to weld.
  6. smooth_criminal
    smooth_criminal Senior Member
    JB weld is the only thing i can think of that will take that heat. Just amek sure you give it plenty of time to cure.
  7. xj0hnx
    C.C.TX.
    I think JB is only good till about 350 degrees, could be wrong.
  8. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    One time my EGR pipe broke off from my EM (89 prelude).
    JB weld will not hold it, it melts off like butter.
    I did find a silver almost concrete looking material in a tube at AutoZone by the exhaust repair kits, the more heat it takes, the harder it gets, it worked really well actually.
  9. drpenguin
    drpenguin Senior Member
    Salem, Or
    Yeah i bet it works good. how do you plan on getting it out?
  10. sk8er602
    Athens, Ga
    jb weld melts then runs onto everything like snot, hopefully some shop close to me can weld it back, thanks for the help
  11. confusatron
    confusatron Senior Member
    Chicago area
    JB Weld cured my grandma's cancer. It saved the 101st airborne during WWII. And it tastes great on toast. :blink:
    That stuffs good for everything BUT high heat stuff, although I have heard of people using it to seal cracked engine blocks. Dunno if that's true though. I used it to fix my compound miter saw. Kicked ass.
  12. xj0hnx
    C.C.TX.
    That's SuperGlue, JB Weld wasn't created till the seventies. <_<
  13. VTECin5th
    Phoenix Az
    i said workED
    I sold the car a long time ago, i never planned on getting it out.
    I also JB Welded the injectors in becuz the o-rings kept melting.
    Yep.. i sold that car :lol:
  14. confusatron
    Chicago area
    It was a joke :)
