almightyaccord
Ok i am wondering how low do you guys think i should go b/c i want to be low but i dont want to mess up my car now. So should i go with.............1.75Front and 1.5Rear or 2.2Front and 2.0Rear.
Originally posted by E_SolSi@May 29 2003, 09:16 PM
generally if the car is ballanced correctly the front will be slightly lower than the rear
so it helps with weight distribution
that helps with traction and handling
also at speed having the front slightly lower than the rear is better for aerodynamics (less air goes under the car... less lift)
my car is set to 6 inches ground to chasis in the rear and 5.5 inches ground to chasis in the front
and SixtySecondAssassin if you could look at my car and tell there is 1/2 inch height difference between the front and rear... you really should be an architect or something
Originally posted by SixtySecondAssassin@May 30 2003, 05:38 PM
im sorry i upset you.
and im not and architect im an engineer.
