how much boost can I run on my F22B1
Discussion in 'Forced Induction' started by Accordian, Sep 16, 2006.
  1. Accordian
    Accordian Junior Member
    I was thinking of either buying a turbo kit ($2,800-$3,600) WICKED EXPENSIVE! or building my own turbo set up, It's a 94 accord ex that has a F22B in it, It's my everyday driver but I like fast too, whats a safe boost level? It's at 150hp what could I expect after turboing it and setting at a safe boost level. I was thinking 200? Whats the best way to go about this? does anyone know of any cheap kits?
  2. pissedoffsol
    psi is a number, nothing more.
    power breaks parts, not pressure measured at the map sensor of air not getting in....
  3. Accordian
    I'd like to have my car running at around 180-210 hp. 180hp is fine with me, it's a lot more than the 150 I have now. I was thinking Log style manifold, T3/T4 and then as far as management, chip my ecu and use hondata. Will I need any other upgrades/changes? injectors?
  4. Accordian
    So to boost my car, it's going to take like $3,000? that sucks
  5. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    94 has the 0-00-0 exhaust pattern right? If thats so you cant do the DSM ghettofab on that motor. You can prolly piece together a kit for half the price but it will require a bunch of metal fab on your part and tuning it yourself. Good Luck :)
    T3/T4E turbo @14psi will do the trick ;) A guy on Honda-tech is running the same setup and made 300ish WHP at 14.5psi. He claims to daily drive it like that so with the right tune I would assume it will hold up.
  6. cb7tunerx
    cb7tunerx New Member
    ^^^ that would be bigdaddyvtec and a friend of mine and i also have the same set-up as he does need any help email me a Gen4acclude@yahoo.com or come on over to Homemadeturbo.com and become a big dog ;) look for gen4acclude there
  7. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    become a big dog? wtf?
  8. Turbo&Auto
    East Burg, PA!
    I like the people here, they all good have a good sense of humor and plenty of knowledge, thanks for the offer though.
  9. 8secHonda
    8secHonda New Member
    i wouldnt run more than 8 pds boost on a stock engine, although i have heard of people running up to 10 but i wouldnt do it... the only way to know for sure how much hp u will get out of a turbo is going to a dyno, this will give u exact numbers..
  10. Matts96HB
    Matts96HB . Moderator VIP
    post split, this is an old thread. :)
  11. 5speed
    5speed New Member
    Wisconsin, USA
    ebay for pipings,wastegate,bov,intercooler,feedlines.
    then go find yourself a good turbo.
