how much boost on these internals???
Discussion in 'Forced Induction' started by 831civic, Oct 5, 2002.
  1. 831civic
    831civic Member
    How much boost can you run on a jdm h22a with JE forged pistons and eagle rods?????
  2. E_SolSi
    about 85lbs .... please read some of the other posts ... there is no way to tell you any reliable numbers without knowing what turbo you are looking at .... and dont just give the size ... different turbos push different amounts of air at different levels of boost... it also depends on tuning ... ive seen people blow the f00k out of engines at very low levels of boost ... :readfaq:
  3. iVtec
    iVtec Member
    i wouldn't boost over 10 lbz...but das juss me
  4. turntune
    turntune Member
    Boca Raton, Florida
    you are correct in your assumption that you need to specify what turbo...for instance..
    I'm running a TD05-14g...now at 15psi this turbo will almost flow 500cfm's, then I ported it..now it will flow 500cfm's...well if I try to put that 500cfm's into my D-series...BANG!, no more D-series, now if I take say a TD05-12a,which flows 320cfm's@15psi...I can brag about running 15psi...but I'm making the turbo work outside its optimum efficiency. So find a turbo that will match what you want your car to do...if you need help,ask...I have almost every turbo compressor map known to be...I can match a turbo to what you need...mathmatically....oh btw...I'm running a 14g@7psi intercooled...about 300cfm's...but the turbo is working at 77% efficiency. B)
  5. pissedoffsol
  6. khan
    khan Village idiot
    Tempe AZ
    i thought you couldnt run forged pistons on a h22 because of the cylinder coating. oh well
  7. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    All you have to do is spend a few hundered on steel resleevings for the H22. It's really not too expensive.
