how much boost?
Discussion in 'Forced Induction' started by elpayaso201, Oct 16, 2007.
  1. elpayaso201
    elpayaso201 Member
    Oregon
    ok i want to know how much boost can i run on a stock b18a1 ls ? with 114.000 miles on it very good motor. with a t3 turbo
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    1,000,000 Psi...
    1 person likes this.
  3. norcalgsr
    NorCal
    :lol: I was going to say the same thing earlier you read my mind!
  4. B16RacerN2NR
    Moving back West...
    :lol:
  5. elpayaso201
    elpayaso201 Member
    Oregon
    haha very funny but really should i keep it under 8?
  6. norcalgsr
    NorCal
    There's a lot more to it than "this motor can run 'x' amount of boost safely" with a lot of it being in the tuning. What kind of engine management are you going to be using? Have you done a compression/leakdown test on the motor to be sure it's in good shape before you add a turbo?
  7. B16RacerN2NR
    Moving back West...
    :werd: the tune will pretty much determine what you'll be able to get away with safely.
  8. SPEEDFREAK0920
    SPEEDFREAK0920 Senior Member
    chI-t0wn fo0
    keep it under 10psi and get a good tune. g/l
  9. Cashizslick
    Good rule of thumb, but again, a good tune is where it's at.
  10. elpayaso201
    elpayaso201 Member
    Oregon
    what would you recomend? i have a chiped jdm pr4 ecu
  11. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if it was me even on a good tune i wouldnt go over 7psi on a stock motor
  12. SPEEDFREAK0920
    chI-t0wn fo0
    is this your DD? 10psi should be fine. just figure from 5-10 on stock engine. what kind of "chip" ?
  13. Cashizslick
    If he has the chip and does not have the turbo setup installed - the chip is definately not tuned for his application.
  14. elpayaso201
    elpayaso201 Member
    Oregon
    its a spoon chip the power band in my car i from 3200 to 7000 rpms so i what engine management should i use . and yes its my dd
  15. pissedoffsol
    psi is useless.
    a GOOD SOLID ls will hold 275-300hp at the wheels.
    if you're is old, weak, or dirty, take 10 hp off for everything crappy about it.
    decide on a figure.
    use X psi it takes to get there.
  16. Cashizslick
  17. elpayaso201
    elpayaso201 Member
    Oregon
    so what engain management system should i use were can a get a tunned ecu?
  18. elpayaso201
    elpayaso201 Member
    Oregon
    do i need bigger injectors?
  19. pissedoffsol
  20. SPEEDFREAK0920
    chI-t0wn fo0
    haha ya man read. A LOT! you can use a few engine managements: chrome,hondata....etc.
