How much degrees does 1 tooth do on a cam gear??
Discussion in 'General Tech and Maintenance' started by gettocrx, Feb 12, 2004.
  1. gettocrx
    gettocrx Member
    Honolulu, HI
    I was wondering,
    How much degrees does 1 tooth off stock timing do on a cam gear for SOHC??
    Thanks in advance!
  2. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    1. how MANY degrees
    2. you want to advance the timing on your SOCH witouut buying a cam gear don you??
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    could you do that??? is that possible?
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
  5. civicious
    Houston, TX
    $150 vs free...
    will it work?
  6. highperboi
    highperboi Senior Member
    Alameda, California
    hahaha
    foreal does it work??
  7. Slammed90Lude
    milford, PA
    actually he said it's a SOHC, so i'm pretty sure he'll just need one cam gear
  8. E_SolSi
    no it doesnt work .... jumping it one tooth puts it WAY out of spec
    not good either way
  9. civicious
    Houston, TX
    me = b16
    me = $150
  10. Slammed90Lude
    milford, PA
    oh i see- well YOU SHOULD HAVE SAID THAT THEN!!!!!
    haha just kidding bro- my bad
  11. hybridsol
    hybridsol Senior Member
    ohio
    yes 1 tooth is way to advanced, so no it will not work, motor wil run like total shit
  12. Smonkeyboy
    Spokane, WA
    yeah, like float a valve as soon as you start it
  13. Sergey P.A.
    Sergey P.A. Senior Member
    253 Tacoma
    my frind didn't adjust his timing belt, his engine runed like shit, and it was only like 1 tooth over, and it was a big difference,
  14. gettocrx
    gettocrx Member
    Honolulu, HI
    no my friends car wasn't running well, this guy did a si head swap on my friends 89 civic DX 4dr. and this guy didn't have a adjustable cam gear or a timing light. this guy said that he had to move the cam 1 tooth advance. is that possible?? I just think when he put the si cam in he accidently move the cam 1 tooth back. thats when the car had ony top end but very slow pick up. so when he advanced a tooth the car ran better. if he moved it one tooth how much degrees off was that?? it run ok but I was just curious! Sorry for all this miscommunication! Thanks anyways!
  15. TWAN
    TWAN Senior Member
    insted of moving the cam gear, just advance the distributor. it is alot easier, and you can fine tune it until youre happy with the performance.
  16. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    OMG, this shit is fucking rediculous........
    buy some fucking cam gears
  17. phunky.buddha
    Dallas / Fort Worth, TX
    Cam timing and ignition timing are two totally separate things...
    I believe that one tooth on the SOHC D series cam gear is NINE degrees. You don't want to advance/retard that much all at once. You might break something.
  18. jamesA
    or in his situation, just one cam gear... :)
    do they make cam gears for sohc's?
  19. civicious
    Houston, TX
    same as the dohc's, i believe....except theres only one of them.
  20. E_SolSi
    f0 sh0!
