Timing Belt-roughly $40
Water Pump-roughly $50
Valve cover gasket-roughly $42
Alt. & A/C Belts changed-about $35
Oil Change-rougly $34
Valve Lash adjust if needed, going to check if any are out of spec- feeler gauges about $4
Grand Total =about $200
EDIT!!! thats assuming its a 1.5 and your doing all the work
hehe my real guess is in the $600s but i wanted to be under by a bit so i could win
ps: i should hope i'm close, i've gotten quotes for most of that before and opted to f@cking learn how to do it myself and cajole friends into helping me. if i remember right, getting the water pump done alone is $300 at a shop, and to do the timing is usually about $150 - so i figure if you're getting the rest done while you're doing the water pump...well yeah it's already all apart so...i'll be curious to see what the actual quote or damage is.
Timing Belt 6.5
Water Pump included
Valve cover gasket .5
Alt. & A/C Belts changed 1.5
Oil Change .5
Valve Lash adjust if needed, going to check if any are out of spec .5
yeah it's a local garage pretty close to my house. My good friend worked for this guy when we were in high school. The owner of the place is a really nice guy.
