how much horsepower does this setup has?
ttvegas2002
hello everyone, I just need some input here please, thanks.
How much power will i get if I do this setup?
lsvtec setup
b16 head, b18a1 bottom end
bottom end is built 11.5to1-
srp forged pistons,
eagle rods,
block guard,
golden eagle lsvtec kit,
12 pound findenza flywheel,
clutchmaster stage 3 clutch,
b16 hydro tranny,
head is stock w/ gsr cams,
aem short ram intake,
aem fuel rail,
b&m fuel pressure gauge
walbro 255 fuel pump,
there might be more i cant think of right now.
p28 w/ hondata s100,
how much do you think this one push out?
Thanks
you can never really tell. there are so many other variables.
i say 170whp because i had an almost identical setup
so you said with this setup can I get a high 14's?
What kind of car is this setup in? You never mentioned that.
In a stripped-down hatch, I would say yes. In an Integra sedan with full interior and some subs? Meh...maybe not...
Yes, I think you can probably hit 14s then, especially if the motor is indeed putting out 160-180 wheel horse. A stock H22 puts out around 160-170 horses, and an H22-swapped EG will run 14s, possibly even 13s depending on the weight of the car, so I think it's definitely possible.
H22s also put out an assload more torque.
yes it does. i say it'll run 14.5 ish.
I'm a crx fan so i really dont find those #'s impressive on a 170is HP motor........if it does put down that much. You could end up like and Andrew. Drop 3k on a single banger only to make as much powers as a stock z6 or so.
what a shame:ph34r:
