How much hp can a d16z6 tranny hold?
Discussion in 'Civic and del Sol - EG and EK' started by thatcivic96, Apr 1, 2009.
  1. thatcivic96
    thatcivic96 New Member
    What the title says, I am wanting to do a mini me swap(d16y7 block y8 head) fully built. With around 13-15psi daily and 25-30psi racing. I am wanting to do a Z6 tranny, but how much horsepower can it hold stock? With a stage 4 clutch.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    hit or miss, you dont have any other choice than to use that trans, its just as strong as the other d series trans. ive saw them bust at 150hp and then again ive saw some with 300
  3. thatcivic96
    What all will I need to do to strengthen it to hold 400-500hp?
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    good luck kid.... you have lofty goals lol
  5. thatcivic96
    It's possible with a fully built D series but thanks for being a smart @$$.
  6. AHHVTEC
    Alabama
    its possible, but more less this will be a full drag car with a d series with that kind of hp
  7. thatcivic96
    Full drag set-up, but still daily driven with the boost tuned down xD
  8. FLounder
    as far as i know theres not much you can do to beef up your d series transmission. just have a spare one ready, and drive it like a grandma unless you are at the track.
  9. 97hatch
    97hatch ?
    Anderson IN
    the d16y8 is the best of all D series trans it has diffrent shift forks that are stronger as far as upgrading it to take more power you can look into installing a quaife and there are also carbon syncros available for it along with custom final drive ratios
  10. thatcivic96
    Okay, so for power a y8 tranny but isn't a Z6 tranny geared better?
  11. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    y8's and z6's are very close if not exactly geared the same. good luck pushing 4-500 horse... sleeve the block.. d's are usually only good for 250-300hp after that you get into longetivity problems... go B...
  12. TurboRex90
    TurboRex90 Golden EG
    Maryland
    Im not saying they arent great trannys, but i have a stage 5 competition 4 puck clutch, only making 235whp, 190 torque and i threw a rod inside my tranny straight threw it.. nice 2 inch whole threw the bell housing and out the other side. Great times. Make sure if you use the Z6 trans, get LSD, and a quaife and have a back up trans ready.
    I've seen D's push well over 500whp on a stock internals. Granted probably wont last long but its both possible and if was built would be able to do it all day long. D series engines utilize more torque then any other honda engines. Ive seen a single cam run 9 seconds. Built by a shop.. cant remember the name off hand. but you get the idea.
  13. 97hatch
    97hatch ?
    Anderson IN
    no d has ever made 500 on stock internals a B motor has trouble doing it hell my D16Y7 streches the head bolts and it only makes 245 at the wheels
  14. Briansol
    the axels are the weak point. you'll snap axels and diffs before the tranny itself.
  15. thatcivic96
    I am not going to run Stock internals, planning on full port polish sleeved, cammed, cam gears, light weight pullies the whole 9 yards, not gonna skimp on anything. So the weak part of build will be cv joints and tranny?
  16. Briansol
    the entire axel, due to not being equal length, are inheritnly weak.
    and the open differential isn't strong either.
    a quaiffe and a set of driveshaftshop or raxels axels ($2k alone) will solve the problem.
  17. TurboRex90
    Maryland
  18. AHHVTEC
    Alabama
    and neither of those are stock, the most ive saw on a d series is 700+whp
  19. TurboRex90
    Maryland
  20. Matts96HB
    Matts96HB . Moderator VIP
    No, don't go B. It'd be backpedaling at this point. Stick with your D, and sleeve the damn thing.
    To the OP: I believe you can get new guts for the transmission from MFactory, MFactory Close Ratio Gears
    If you want different ratios, call them up and talk to them, they're pretty cool.
