How much hp??
Discussion in 'General Tech and Maintenance' started by mozzandherb, Aug 2, 2005.
Thread Status:
Not open for further replies.
  1. mozzandherb
    mozzandherb Senior Member
    I know this is a very generalized question to ask, but how much hp at the crank can I expect with this setup?
    92 Accord weight 3000lbs
    jdm h22a
    exedy stage 2 clutch and flywheel
    over bored throttle body
    throttle rotor
    aem cam gears
    aem fuel rail/fuel pressure regulator
    hondata s100 chip
    zex 75 dry shot
    4-2-1 headers 2.5 outlet
    2.5 inlet/outlet cat converter
    aem short ram intake
    cat back exhaust
    I think that's it. Any guesses?? Thanks
  2. drpenguin
    drpenguin Senior Member
    Salem, Or
    Thats what a machine called a dyno is used for. you can expect all the HP in the world. doesnt mean your going to get it
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    A GUESS:
    Most of those arent power adders.. Not by themselves. Like cam gears. They can only hurt your power unless you dial em in on a dyno.
    Overbored TB: 2 HP. maybe, probably not though.
    cam gears: 0, unless tuned properly.
    Fuel rail/press reg: 0
    hondata chip? Has to be tuned to your car to do any good.
    headers: 7-8 hp?
    intake: 4-6 hp
    converter/exhaust: 7 hp
    Zex 75 shot: 75 Hp.
    THIS IS JUST A GUESS, put the flame throwers away.
  4. formby
    formby learning in progress
  5. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    1003937786874867637622 hp to the crank for sure. Another one of these huh?
    maybe if you are lucky 200 to the crank but I doubt it.
  6. mozzandherb
    Thanks for the guess, I hope your right! B)
  7. integraslut78
    KiLLa kALi
    Oh I didn't see the Zex kit in there the first time I read this so I would like to change my original answer from 200 to 250 to the crank :)
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
Thread Status:
