i prefer to thin the shit out of primer, and then spray many coats, with sanding in between, your car will come out smooth as fuck if you use this method...
most martin senour primers will NOT list a mixing ratio....what is the part number and name of the primer? most primers i use take 5155 tec hardener so im not sure what u have if u say u dont need hardener...and also as a general rule for a nice think high building primer that can be used to sand out imperfections, and or blocked out to get something very straight i use a ratio of 4:1:10%. 10% being reducer, and 1 part being hardener. otherwise without know what it is for primer specifically i cant tell u much more
