How much would you pay
Discussion in 'Civic and CRX - EF' started by hazzardboy95, Apr 2, 2008.
  1. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    My friend is picking up a 1991 crx with a jdm b16 swap, lsd trans, hasport mounts, hasport shift linkage, full upgrade integra brakes front and rear, steel braided brakes lines, skunk2 manifold, aem rail, aem regulator, cold air, clean interior, slight body rust, jdm fenders, hood, front bumper, and other little goodies.
  2. BrutalB83
    Rochester Hills, MI
    $3,000, depending on the mileage.
  3. hazzardboy95
    Pasadena, Md
    Probably no more than 40 000
  4. Hasid Lafre
    Hasid Lafre Master of the obvious
  5. BrutalB83
    Rochester Hills, MI
    One million dollars maybe?
  6. get_nick
    Washington State
  7. SlushboxTeggy
    NJ to MA to CA
    Me-What was the last bid?
    Bob-$1.
    Me- $2 Bob.
  8. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Well...I'd have to see some proof that it's LSD.
    I'd pay $3,000 if it is, $2500 if not.
  9. get_nick
    Washington State
    fuck ^_^
  10. BrokenRex
    BrokenRex New Member
    test drive it. have a friend hop in, put e-brake on and do a burn out. if both wheels spin, 3k-4k depending on the overall condition of the body, interior and any leaks. if only one wheel spun, i'd thank the guy for his time, then apologize for catching him in a lie and wish him luck screwing the next guy over.
  11. hazzardboy95
    Pasadena, Md
    Lsd is stamped into the trans up near where the tag for the block identification, its not an after market lsd its straight from japan lsd.
  12. get_nick
    Washington State
    you do realize you can test for lsd by jacking the front and spinning one wheel and if the other spins the opposite direction its lsd.
  13. Hasid Lafre
    Funny you should say that cause after checking for bad wheel barrings on a few previous cars in my days they all did that and they wernt lsd cars.
  14. get_nick
    Washington State
    what cars were they? if it is an open dif, one will spin and the other shouldn't do anything.
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no more than 3500-
    and get_nick,,your theory isnt exactly true,,my d16 si spun the tires 2 diff ways,
    you should be able to tell when going around the corner and giving it some throttle,,it will feel way diff, than a normal trranny
  16. 97hatch
    97hatch ?
    Anderson IN
    $0.27 or best offer who knows with out looking at it thats like saying how many beans fit in a corn bag. you dont know till you try it
  17. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    Depends on if I could buy it, and turn around in the same 5 seconds and sell it for $1000 more.
  18. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    Whether you pay $3000 or $5000 all that matters is that you are happy. I have well over that in my car. If the work was done right and it looks like a decent car then make an offer. It would cost more to build a car than to buy it. Post up some pics so we can get a better idea.
  19. hazzardboy95
    Pasadena, Md
    If i can i will, oh and as far as lsd, both tires should spin in the same direction if you jack it up. Not exactly sure if its the same on a fwd but in rear wheel drive there is a spring pushes up against two small clutch packs in the diff and when the ass end is up they spin in the same direction cause the clutch packs are stuck together. It takes driving around corners to make the axels spin at different speeds to make the clutch packs release. I know its not exactly the same but its a concept.
  20. daveholiday
    daveholiday Do work
    I thought your friend was buying it?
