How Much $
Discussion in 'HYBRID -> EG-EK / DC' started by vdubber, Apr 4, 2003.
  1. vdubber
    vdubber Member
    ;) I was just curious, how much $ should it cost me to do a b16a1 swap into a crx hf. I can get the engine package for either 1350 from nippon-motors.com, or 1150 from jdmpower.net? then i would have to buy shiftlinkage, axels, motor mounting kit, and to make things easy a wiring harness conversion kit. This would run me upwards of 2350 either option. Should i do this or buy a sir front clip for 2100 and have it shipped for 350? or is there an easy way to do this without spending close to 2400 mark. IM doing install myself but i keep hearing how people get these installed for under 2k. want some of your thoughts plz.
  2. Civicdrgrcr
    Civicdrgrcr Junior Member
    Axles aprox. $200-250
    Hasport Shift linkage $149shipped
    Hasport Mounts $379 shipped
    DX/SI Hubs- $Free-150
    Doing it yourselve you learn the hard way. Let a shop do it. 98%time it's done properly.
    Where are you from. If you are in the VA area. I can hook you up with swaps.
    Hit the email.
