How Mutch Boost Out Of A Td05h Help Fast
i need to know how mutch boost a 93 Talon TD05H turbo can put out?
and what would make the turbo look up every now and then? poor lubrication?
and what is he max you would pay for one that looks up like that?
it will put out about 20 psi..... but it still is a small turbo.
talon's run 14 psi stock, and make 200 horse on their 2L motors.
if its locking up, dont buy it. you can get a better one off ebay for $75
Ahhhhh hope I cought this thread in time. The 14B from the 1st gen Talons are good only up tp 16psi. We ran one at 16psi for 2 weeks and then swapped it out for a Big 16G ported and clipped 10 degrees. When we took the stock snail off we noticed that the housing around the wastegate(both sides) was cracked to hell. Those 14B's cant hold too much psi. I would recommend saving your money to upgrade that turbo!
