How similar are the p75 and the P05
Discussion in 'ECU's, Electronics, and Tuning' started by jimboburgess, Jul 11, 2005.
  1. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    will my b18b run on my CX ecu?,
    So i can pull the ecu to install uberdata or crome on it? I haven't researched crome yet. does the ecu need to be in my car while i am tuning it?
    I realize that the fuel mixture will definently be really lean.
    Could i just tune my CX ecu and keep the p75 as a back-up.
    I am tuning it in need of boost recognition.
  2. reikoshea
    Dallas, TX
    With Crome or Uberdata it really doesnt matter as long as the car is OBD-1. You can change your fuel mixtures to suit your application. You just need a base line to do it.
  3. jimboburgess
    nyc
    both are obd-1. If i download/create .bin files, do they include the base line i need to run a b18b off an ecu from a d15b8. since i am boosting the engine am i going to use a whole different set of a/f maps in the first place.
  4. reikoshea
    Dallas, TX
    Im not really sure...id say check around pgmfi.org
    Im sure someone there has some baselines for an LS
  5. jimboburgess
    nyc
    yeah, I checked it out and compared, the ECUs are visually identical, so i figure i could just load up the .bin i need plus the p75 if i need it still.
  6. pissedoffsol
    throw the p75 map on the p05 ecu, and the p05 will act like the p75, so long as it has all the same features. i know the p06 dx ecu works... but i've never heard of the p05 being used. there might be something weird on the cx ecu.. i can't confirm that though.
  7. jimboburgess
    nyc
    the difference is the O2 sensor, the LS has a 4 or a 2 wire, and the CX has a single wire. so if i change that, it works just fine.
  8. nfn15037
    nfn15037 Senior Member
    Disable the 02 heater circuit or add Q30 to the board and run the heater wires.
  9. pissedoffsol
    forgot about the o2 heater... yup- that should do it. i can't think of anything else that the cx has differently than the dx...
