How To Add Or Extand Wires From Cpu?
Discussion in 'ECU's, Electronics, and Tuning' started by hondacivicnos, May 6, 2003.
  1. hondacivicnos
    hondacivicnos Senior Member
    How to add or extand wires from CPU?
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Cut and solder.
    Why do you want to E-X-T-E-N-D the wires?
  3. solblu
    solblu Senior Member
    Ricer
    Well if you have a standard pull out the auto tranny pins, cut the wires up 10 inches or so and put them where you need a wire in the harness. Then solder on the wires you are running to the engine bay.
