how to calculate compression ratio
reckedracing
TTIWWOP
VIP
4 cyl
2.2 liter displacement
225 psi compression test...
anyone know how to calculate the CR?
its a 2001 H22A4, but a motor builder told my friend he had 11:1 compression which would be a typeS...
i get 280psi on 1.8L b18cR with 12.3:1 pistons. but you cannot get your CR from a compression test.
[post=433412]Quoted post[/post]​
My cheapo 300psi gauge is pegged after 4 pumps.... :(
mine maxes at 300psi also :)
[post=433546]Quoted post[/post]​
Naw- I know mine goes way higher than that... I need a gauge that reads higher than 300psi.
hcivic.com
@Dec 17 2004, 01:58 AM
the only real way is to cc the block and head if youve got it apart it takes 10 mins to do
[post=433555]Quoted post[/post]​
:werd:
