1. Purchase a Helm's Manual for the specified engine
2. Turn to the cooling section
3. Order specified parts from nearest Honda dealer
4. Follow instructions in Helm's manual for installation
Seriously though, buy a Helm's. It will be the best $60 you can spend on your car.
i can give you a quick how to but a manual is best for a first timer.
set engine to top dead center and make sure all marks are lined up (cam and crank)
remove all belts
remove power steering pump
remove ac tensioner
remove side engine mount
remove crank pulley
remove timing belt covers
remove timing belt
remove water pump
repeat in reverse
but seriously buy a helms or do it woth someone that has done one before
