How to eliminate electrical hum in stereo
Discussion in 'Car Audio / Security / Electronic Accessories' started by wikedeye, Apr 3, 2009.
  1. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I installed a stereo in my car a while ago and the ground to the head unit was bad. I ran a new wire from the head unit and connected it to where the stereo frame and the floor pan meet (the bolt that holds the dash to the floor). Now I get hum in the speakers occasionally. Is it just that where it is ground is not a good spot or could it be something else? Where is a good ground spot? Would finding a better spot fix the problem.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just beef up and get a better ground
  3. wikedeye
    Savannah, Ga.
    A better wire or a better spot? Where is a good spot?
  4. AHHVTEC
    Alabama
    as long as its on the metal of the car it should be fine, but beef up the wire, it sounds like it dont have a good connection
  5. wikedeye
    Savannah, Ga.
    Ok thanx for being the only guy who helps people out nowadays.
  6. AHHVTEC
    Alabama
  7. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Hey Conan, I JUST saw this post. What your getting, I have learned, is called "alternator whine". What gauge wire are you using? I would suggest at least using an 8 gauge, though personally I usually go with 4 gauge, just in case. I'm trying to remember how my audio guy fixed mine which I think he moved where my power wire was routed in the engine bay as well as where my ground wire was connected to. I'm not sure if this will help but that is what I can recall. Good luck my friend. :thumbsup:
  8. wikedeye
    Savannah, Ga.
    I dont remember what guage it is exactly, but I know it was thicker then what was used in the original harness. I might not have to work today so if I dont I will take a look and try to fix it.
  9. MthaFuknGreen
    Lodi, CA
    get a bigger ground wire and sand clean the spot your ground is attached too and make sure its nice and snug on there. make sure you didnt route your power wire along the same side of the car as that audio wires.
  10. wikedeye
    Savannah, Ga.
    I am not using an amp or subs, just factory size speakers and a head unit.
  11. MthaFuknGreen
    Lodi, CA
    oh.. lol
    reading>me.
    try grounding the negative on the speakers directly to the frame near them.
  12. TommyTheCat
    TommyTheCat Gonzo Scientist
    Minneapolis, MN
    Whoa - dont ground any of the signal/power wires jackass. And you dont need much more than 12 guage wire to ground a freaking headunit guys.
    Are you getting just a hum or is it like a whine that changes frequency with your rpms? One is just a weird electrical loop while the other is noise from the alt (which im guessing you dont have). You said you only get it "occasionally" - can you elaborate on this?
  13. wikedeye
    Savannah, Ga.
    It is actually alternator whine (changes frequency with rpms). I dont usually notice it while driving forward, but if I reverse there is no mistaking that it is there.
  14. MthaFuknGreen
    Lodi, CA
    who said anything about grounding the signal or power wires?
  15. TommyTheCat
    Minneapolis, MN
    You did when you told him to ground the negative of his speaker. Sorry I dont know what you would refer to the speakers' signal/power cable (since it transmits signal or power).
  16. CRX-YEM
    Wallingford, CT
    To get rid of alternator whine you need a bipolar bypass capacitor, also the ground point to the frame of the car make sure it's got a really good contact sand away a bit of the paint and use dielectric grease. Also it might be quite possible that the point you chose for a ground is creating a ground loop.
  17. newb
    newb phresh VIP
    Backwoods Northwest
    Another common problem with ground wires is their length. Just somethin to consider.
  18. wikedeye
    Savannah, Ga.
    A capacitor is a bit overkill for my problem, but I will check the ground point and make sure it is clean.
  19. CRX-YEM
    Wallingford, CT
    the bipolar cap is a very small one just to block the alt. noise. It's not one of these overly huge caps used in monstrous audio systems.
  20. awptickes
    MD
    1 person likes this.
