how to get bigger brakes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by mygsr, Dec 10, 2005.
  1. mygsr
    mygsr Member
    LOS ANGELES
    i would like to know what parts could i use to add big brakes using oem honda parts
    i read on honda tunning magazine that using some prelude rotors and some legend caliber it could work can any one help me on which parts are going to be needed
    i have a 94 civic
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Get a full setup from a 94 GSR. Bigger than civic brakes all the way around. Not ALOT bigger, but bigger, and better quality calipers.
    I have heard of 'lude rotors and certain calipers but haven't ever seen anything like that in person.
  3. mygsr
    mygsr Member
    LOS ANGELES
    alright then thanks for the info
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yea,l it easiest just to use the GSR parts, and cheaper too.
  5. H_doubledeuce_a1
    H_doubledeuce_a1 Junior Member
    If you wanna go big-balla, swap in a 5-lug type-R conversion. 94 Civic + 5-lug = hotness. [​IMG]
  6. thegreat1310
    thegreat1310 Senior Member
    frederick,md
    willwood has a kit for 600 bucks its the best way to go i think
  7. reckedracing
    reckedracing TTIWWOP VIP
    NY
    yea, but that willwood kit is only brackets with bigger rotors right? and you use stock calipers?
    i read somewhere about using the lude rotors and other calipers too and i am also very interested in the idea
    anyone know where to get more info on this?
    i;m gonna have to look through my stack of magazines i think...
  8. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    http://www.hondavision.com/forum/showthread.php?t=68693
    http://teamdelsol.com/technical/howto/bigBrakes/default.asp
    Other calipers that can be used are NSX calipers but the directions vary slightly on what caliper brakets to use
    With several of the above, you need to first have a 10.4 inch brake setup to begin with (GSR/SI brakes) So it would be smart to first up to the 10.4 setup, drive around see if you like it, and if you feel you need bigger, up to the larger rotor setup. Also, it is highly advisible to jump up to the 15/16th size master cylinder otherwise the pedal will have a ton of pedal travel before they actually engage. Easiest way to do this is to buy a 15/16th mastercylinder from a 91 civic EX 4 door..
    http://honda-tech.com/zerothread?id=364783
    Oh and this belongs in the Brake Section....[​IMG]
  9. B18C1civic96
    B18C1civic96 Member
    5-CARS IN FRONT OF YOU
    use the nsx dual pistion calip on the lude rotors everything swaps in
  10. B16
    B16 Super Moderator VIP
    yay area, CA
    No, the Wilwood kit also comes with the 4pot dynalite calipers for that price. Advise you'll need 16" wheels for that kit.
    The legend calipers are identical to the NSX calipers with slightly larger pistons. You would have to redrill the prelude rotors to make them 4x100.
    And, +1 to everything asmallsol said.
  11. asmallsol
    Legend calipers are slightly diffrent in that they do not have cooling vaines and the NSX calipers do however they are also like twice the money as legend calipers, but as you said, they do have slightly more piston surface area
  12. DelSlo
    DelSlo Senior Member
    you just said you read in honda tuning about the swap, i have that mag too, dont ask what parts you need, IT SAYS IT ALL IN THE ARTICLE! read it again and make a parts list.
    the mag has a BLACK JDM EF Civic on the front with a massive intercooler in the front bumper. and the cover says BOOSTED. i cant remember the month but thats the cover to look for. have fun.
  13. brian11to1
    brian11to1 Senior Member
    nsx calipers/rotors.
  14. E_SolSi
    mmmmmmmmm brake cooling ducts [​IMG]
