how to idenify different heads
Discussion in 'Civic and CRX - EF' started by 91crxracer, Oct 8, 2007.
  1. 91crxracer
    91crxracer New Member
    How do you find out what head is on a motor if someone says they swapped it? I don't know on hondas yet but i know some have different casting #s. is there a site that tells you which ones are which? thanks for any help you can give
  2. file-error
    file-error New Member
    put a picture up and people here will let you know what it is
  3. eg6sir
    take a picture of the castings in the head.. right above the exhaust ports
  4. 91crxracer
    like pm3-1 / pm5-8 or what?
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    there should be a code on the side(i think the intake side) like pm6 or p08....then go to google and type in HONDA ENGINE CODES and one of the links is an awesome writeup...itll tell you everything u need to know
  6. norcalgsr
    NorCal
    Not the intake side..
