How To Lower Boost
Discussion in 'Forced Induction' started by import_racer, Oct 17, 2002.
  1. import_racer
    import_racer Member
    I have a deltagate wastegate that is supposed to be 7 - 9 psi. Screw is all the way down, but my gauge says that it at 9 psi, that is with the intercooler. How can I lower my boost? I have a rev hard stage 2 on a b16 in a 92 hatch. Here is a link to how it looks like. In other pictures, the wastegate points to the left and mine points up. It looks like it is installed right. Any help on how to lower my boost will be greatly appreciated. Thanks!!
    http://www.cardomain.com/id/import_racer75
  2. SixtySecondAssassin
    Austin, TX
    maybe get a longer screw with the same pitch. or buy a boost contoller. or make one.
  3. pissedoffsol
    doesnt matter-- boost controler only goes UP. the spring in the WG is the LOWEST it will go.
    change the spring if you want to go lower.
  4. knowledge
    knowledge Senior Member
    Beale AFB, CA
  5. import_racer
    import_racer Member
    How do I change the spring and where do I get one????
  6. pissedoffsol
    spring is in the wastegate. depending on the waster gate brand, it will be different. get a spring from the same company (tial, deltagate, hks, etc)
