how-to ls motor into a ef
Discussion in 'HYBRID -> ED-EF / DA' started by makewheelies304, Aug 14, 2008.
  1. makewheelies304
    makewheelies304 New Member
    ohio
    anyone have a good how to on puttin a b18a1 in a ef?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
  3. makewheelies304
    ohio
    ok i had a 90 civic hb 3 years ago and i swapped a zc in it..i sold that...well now i bought a 91 civic hb std. for 500 bucks...with not a spot of rust!!
    i just bought a b18a1 and i ordered mounts and the shift linkage.. and i also have the si knuckles. and i have a .60 trim t3 t4 turbo and intercooler with piping and greddy bov
    but what i really need is a cable tranny!!!!
    what ecu will i need? ( the car is getting turboed, so idk if that matters or not?)
    what axels will i need?
    will i have to do any fabricating to make it fit?
    and i need more turbo parts!
    if you can help me that would be awsome
  4. capricefrk013
    capricefrk013 is waiting for summer
    NE OHIO
    The search button will be your best friend.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    axles=90-93 integra axles with intermediate shaft,
    do you wanna stay obd0???or do you wanna convert to obd1??
  6. makewheelies304
    ohio
    im not doin the wiring..my buddy is so would obd1 be better?
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    is the car an si?!?!
  8. efhondakid
    Akron-Canton, Ohio
    Nice find.
    Ok, at least you've done some research.
    You can use a hydro, but youll need the hydro to cable adapter from Hasport.
    PR4, (comes in OBD0 and OBDI) I would do an OBD conversion and run OBDI, there are better tuning programs for OBDI. Many people use Crome because its free and many shops are familiar with it. Do a lot of research about proper tuning, and youll be glad you did.
    DA Integra.
    :no: Other than pounding a dent in the drivers side frame rail for alternator clearance.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    and bending the lip down on the rear crossmember for the tranny bracket
  10. LightWeightChamp
    LightWeightChamp Honda FTW!
    MN
    i have a ys1 cable trans for sale
  11. efhondakid
    Akron-Canton, Ohio
    With some mount kits you dont have to do that, and some you do.
  12. BrokenRex
    BrokenRex New Member
    you'll also have to bend/cut/smash/melt/etc. the front trans mount bracket off of the crossmember. your trans will contact it if you dont.
  13. makewheelies304
    ohio
    nope its a std.
    and thanks guys for the help...im gonna take pics today and post my progress!
    i really dont wanna do the hydro conversion but its startin to look like im gonna have to! i got innovative mounts so i hope everything clears!
  14. INJEN78
    INJEN78 HS LEGEND
    OHIO
    just pund a dent under the shock tower,gring of the front tranny mount on the front cross member,and pund the lip down where the tranny bracket goes on the rear crossmember,and i think you have to convert to mpfi,im not familiar with std's:D
    and you can sell the hydro tranny for more than a cable tranny costs
  15. George777
    George777 ^^ Likes Bewbies
    With your mom
    :ph34r:
  16. makewheelies304
    ohio
    well i got great news!! i just aquired a cable tranny in great condition, mounts and shift linkage for 425 bucks!!!
  17. makewheelies304
    ohio
    my first ef 3 years ago..with a zc swap
    heres the new whip
  18. makewheelies304
    ohio
    heres the b18 i got for 100 bucks..needs cleaned up
    the tranny that was on it is destroyed!
  19. makewheelies304
    ohio
    i cant get the intermediate shaft out either...any tips?
  20. makewheelies304
    ohio
    and what throttle cable will i need?
