how to make y8 intake manifold work on swap
Discussion in 'HYBRID -> EG-EK / DC' started by slammedb18acivic, Jun 4, 2005.
  1. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    now we all know the y8 is obd2. but is there a way i can make the y8 manifold work because the piping is bigger. there is a plug on the 94 manifold that the y8 doesnt have. any suggestions. can i eliminate the purge valve? thanks alot for you help
  2. pissedoffsol
    no, you will throw a code if you elimanate it.
    just mount it on the firewall, and give it a vac source.
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    you are talking about the IAt sensor. on the 6th gen, the located on the airbox, and not the manifold. drill and tap the y8 mani on the huge flat spot on the 1st runner (side) this is waht I did. pretty easy!
    matt
