How to read ECU codes on Civic DX 1993
Discussion in 'Civic and del Sol - EG and EK' started by latreche34, Nov 13, 2006.
  1. latreche34
    latreche34 New Member
    Hey guys I have a Honda Civic DX 1993 1.5L Sedan Automatic I have a starting problem. After checking fuel, distributor, s. plugs.... insatalled new main relay but everything passed the test, so I'm trying to read the ECU codes -note that the Chk engine light comes on and goes off normally- according to the fellowing thread, however I couldn't find the 2 pin brown and black arround the ECU, can anyone experienced the same problem? Thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its under the pasenger side dash they put it away good in there sometimes but its ther it will have 2 wires going to a plug,, but if theres no check engine light then theres no need
  3. latreche34
    I have been able to locate a 2 pin plug covered with green rubber and it's not black and brown, by juping that I get a steady engine light, I'm trying to see if my ECU is good.
