How to remove 92-95HB rear seats???
Discussion in 'General Tech and Maintenance' started by Bonez, Nov 15, 2003.
  1. Bonez
    Bonez Junior Member
    Yep i have a 93 HB and i want to know how to remove the rear seats w/o messin them up more thn they already are, cuz the dickhead that stole my amp ripped it out the seat and the seat is all off track n messed up but bottom line how do u remove the seats it comes halfway out and stops!?!?!?!?
  2. Accordturbo94
    Accordturbo94 Senior Member
    Just unbolt them! Easy as 1-2-3
  3. BigJ
    Good Question, I need to know this also? In my haynes(yeah I know I need a helms) it says 2 bolts, which I've got but that's it. I think there is a bolt underneath on the bottom, but I'm not 100% sure. If you find out, post how please.
  4. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    im guessing its the style where there are clips on the underside that go into the floor and there also should be one or two 10mm bolts going through a metal eyelet on the back of the seat. these bolts are usually found in the crack between the back support seat and the seat for your ass (the crack where all your change falls into)
  5. BigJ
  6. swanny
    sometimes you gotta yank pretty hard on the seat to get the clips to release
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    muscles and power - and pulling power.
  8. Bonez
    Bonez Junior Member
    Anyone out there already have this done willing to share tips cuz i'm about to jus rip this SH#$%T out!!!!!
  9. swanny
    which seat are you taking out? to take out the vertical backseat there should be some 10mm bolts underneath the cloth at the bottom.
  10. Bonez
    Bonez Junior Member
    yea i waz trying to remove the rear bench.
  11. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Actually there is a clip on each side around the pegs on the outsides, that if you pop off, they just come out.
