How To Remove Rev Limiter On Obd 2
Discussion in 'ECU's, Electronics, and Tuning' started by Sprocker, Jan 17, 2003.
  1. Sprocker
    Sprocker Senior Member
    I have a Turbocharged Honda and am buying a built head with Turbo PnP an would like to get rid of my rev limiter(stock limiter is at like 6300 rpm). Whats the easiest way and cheapest way to do this. I am only running low boost and trying to extract as much power as I can before uping the boost and then if I go above 10 I will get the full stand alone system! This is a 2000 OBD 2 ecu so I am wondering if its possible to get rid of it without swapping to a Full stand alone system.
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    are you still running a stock block?? if so i wouldn't be touching that rev limiter
