how to rewire a 93 civic obd1 dizzy to 91 civic dpfi harness
jasonga30224
i have 91 civic that im doing the mpfi conversion on it but my dizzy is from a 93 civic obd1 it fits my engine but how do i wire it up because i cant find a 88-91 si dizzy or harness.any help would be hoghly appreciated thanks.
rather then change the distributor, you could convert the engine harness to have obd1 style plugs, and then it would plug right in to your 93 dizzy.
unless you are converting the car to run an OBD1 ECU, you can't use the OBD1 distributor - gotta have OBD0 distributor with OBD0 ECU
the 90-93 integra is an OBDO but it is for a B series engine. If anything you need a dizzy off an 88-89 integra with the D16A1 but you have to cut one of the tabs off it or it will not bolt up.
are you just trying to convert the car the MPFI or what?
