How to Rip/Edit DVD and Convert Video(for Mac/Windows)
Discussion in 'HYBRID -> EG-EK / DC' started by wondering03, Apr 8, 2009.
  1. wondering03
    wondering03 New Member
    Attention please:
    Mac and windows users:
    Do you want to rip your DVD to play it on your portable devices?
    Do you want to convert your video to your iPod/iPhone/Zune/Mobile Phone/PSP/iRiver/Sansa?
    This article is a full solution to solve all the questions above.
    It includes three parts:
    Part 1: How to rip and edit DVD and convert Video on Mac OS X with one tool-iSkysoft DVD Ripper Pack for Mac
    Part 2: How to rip DVD and edit DVD on Windows with Best DVD Ripper software-Aiseesoft DVD Ripper
    Part 3: How to convert video with Best Video Converter -Aiseesoft Total Video Converter to convert your videos on your portable players anywhere and anytime
    Step 0: Download and install iSkysoft DVD Ripper Pack for Mac(Intel Version or Power PC Version)
    With iSkysoft DVD Ripper Pack for Mac, you can rip your DVD and also edit the videos.
    Step 1:Select and run “DVD Ripper for Macâ€, Click “Load DVD†button to load your DVD[FONT=&#23435].[/FONT]
    Or, click “Load IFO†button, browse your computer, find the DVD folder of the movie you want to add from your hard disc or DVD-ROM, open your DVD folder, open the VIDEO_TS folder, select all the IFO files and click OK.
    Step 2: Output setting
    Set the output format you want from the “Profile†drop-down list.
    Click “Settings†button to open the Settings window and set video resolution, frame rate, bit rate, encoder, etc. iSkysoft DVD Ripper for mac lets you extract audio from DVD movie to MP3 or AAC, etc.for web using or other portable players. You can set audio resolution, frame rate, bit rate and encoder on the “Settings†panel.
    Step 3: Cilck “Convert†button to start your conversion
    Waiting a short while, the conversion will be finished.
    More editing functions
    1.Trim
    Click the “Trim†button to to trim the current title or chapter by dragging the Start Time slider to set the start time, and dragging the End Time slider to set the finish time. Then you can only rip segments from dvd on mac.
    2.Crop
    If you want to remove the black edges or just convert an area from your movie video, you can click “Crop†button to crop the video of the current title or chapter. You can specify an area either by dragging the frame around the video or setting the crop values: Top, Button, Left and Right.
    3.Capture pictures
    With this program, you can preview the movie in the preview window on the left of the main interface.
    While previewing the movie, you can capture pictures by clicking “Snapshot†button. Click the Snapshot Folder button to open the folder where the captured pictures are saved. You can also specify the folder where to save the pictures. Choose a format (JPEG and BMP) for the captured pictures to be saved as. Then Click Ok to finish the settings. You can find the pictures in the the folder you specified.
    4.Effect
    If you want to adjust the video effect of your movie, you can click “Effect†button and drag each effect adjustment slider to set the video brightness, contrast, saturation and video volume. You can also choose a special effect from the Effect drop-down list to apply to your movie.
    With iSkysoft DVD Ripper Pack for Mac, you can also convert the video to the formats you want.
    Step 1: Select and run "Video Converter for mac" and then click “Add File†button to add your video.
    Step 2. Output format and Settings
    From the “Profile†drop-down list you can find one format that meets your requirement.
    To have your own video settings you can click “settings†button.
    After doing the 2 steps above, you can click “Converter†button to start conversion.
    If you want to edit the videos, the functons such as "Capture your favorite picture", "Crop video", "Video Effecting","Trim video","Merge videos into one file" are also available and very easy to use.
    Part 2: How to rip DVD and edit DVD on Windows with Aiseesoft DVD Ripper
    Step 1: Download and Install Aiseesoft DVD Ripper.
    Step 2: Click “Load DVD†button to load your DVD.
    This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
    Step 3:Select the output video formats you want from the “Profile†drop-down list.
    Then you can click the start button to begin the conversion
    Part 3: How to convert video with Aiseesoft Total Video Converter
    Step 1: Install and Run Aiseesoft Total Video Converter and then click “Add File†button to add your video.
    After doing the 2 steps above, you can click “start†button to start conversion.
    Now no matter you are Mac or Windows users, enjoy your DVD and videos on your portable device is so easy, no waiting, just have a try!
    Tipard iPod to PC Transfer
    Mac Video Converter
    Best DVD Ripper
