how to safely store a engine
Discussion in 'General Tech and Maintenance' started by rextc, Aug 6, 2003.
  1. rextc
    rextc Member
    i was wondering how to best store an engine if it will be a couple months before i can put it in my car
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    make sure all fluids are drained out of it, cover it up with a tarp.
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    try to store it in a dry place. In damp places, some things can start to rust.
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    go to crapy tire and byt a can of ant rust spray and coat it also dont drain the oil replcace it with clean oil so there is somthing in there to protect the internal parts
  5. rextc
    rextc Member
    well someone said drain the fluids and someone said keep oil in it? Which one
  6. D See 2
    D See 2 Senior Member
    Baltimore, MD
    drain all coolant. leave oil
  7. rextc
    rextc Member
    ok so it will be ok for like a month or two
  8. CRX-YEM
    Wallingford, CT
    and remember to drain the oil and replace with NEW oil before you start the motor after you install it. This of course is after it's been stored for a while
  9. rextc
    rextc Member
    ok thanks cause i dont have the time to do the swap now cause im startin football amp so it will robally be like two or three months
  10. rextc
    rextc Member
    haha yeah the money part is cool but hey it pays for my college so i guess it save me money in a way. but thanks for the help il mae sure to keep it covered up
  11. rextc
    rextc Member
  12. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    keep the oil, the coolant should be out, I wrapped my motor up siran wrap to keep the humidty out of rusting shit up.
    Milan
  13. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If your just storing it for a couple months, it will be fine as is, as long as it isn't in a humid place. Mine sat in my basement for a couple and was fine. Do you think that all the places on line do anything special, or junkyards? I've seen motors sit for months and months and they are fine.
  14. IDMaxGuy
    IDMaxGuy Senior Member
    MO
    if u wanna get professional they make motor bags....
