how to tap for oil
Discussion in 'Engine Building' started by hatchzrul3, Jun 16, 2010.
  1. hatchzrul3
    hatchzrul3 New Member
    for a b18a how would i tap for oil for a ls vtec build
    1 person likes this.
  2. Magana559
    Magana559 The Warden
    fresno Ca
    you dont have to tap, sandwich plate on oil filter, ss line to head(remove freeze plug on left side of head).
  3. Matts96HB
    Matts96HB . Moderator VIP
    couldve just left it at this, and let him find it on his own
    negative rep wasnt necessary. doing shit like this causes more bullshit than its worth. repped the OP to put him back in the green.
    now, back on topic:
    OP, just as magana559 stated, you can use a sandwich plate on the oil filter which is probably the easiest way of doing it. otherwise you can remove your oil pressure sending unit and put a "tee" there, and run a braided stainless steel line from there to previously mentioned freeze plug on the cylinder head.
  4. BP203
    BP203 New Member
    I personally wouldn't tap it myself. I would either have a shop do it, or just buy an aftermarket name brand with one that comes tapped brand new. The way I look @ it is, you're going to spend how much money on a turbo, plus installation, and a tune, why not just spend another $200 or so and buy an oilpan that comes tapped. I wouldn't want to take the risk of f*cking everything up. Call me paranoid, but that's my oppinion.
  5. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Playoffs??!!! You're talking about Playoffs??!!
    No Turbo here.....its not at the oil pan either. This is a Frankenstein motor and it needs more oil for a VTEC head
