how to tell a true b18cr
Discussion in 'HYBRID -> EG-EK / DC' started by badassgixxer, Sep 17, 2008.
  1. badassgixxer
    badassgixxer badassgixxer
    maryland
    is there any way to tell if i have a real b18cr motor.
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    If it's a true Type-R the block will be stamped with B18c5 (USDM) or B18c (JDM). But you could have easily found this out had you first googled it or done some searching.
  3. badassgixxer
    maryland
    well i did but im new at this swap thing and i saw some things that dident make sence like my d16y7 has stampt pe2 on the block by the intake and my ecu matches that .my swap block has b18c on it and stamped p72 by the intake and i have a p73 ecu.and i look up ecu and ap73 goes with a 96-97 b18cr and a p72 goes with a18c
  4. eg6sir
    look at the casting in the head, right above the exhaust ports.. if it says pr3 then its a type r head.. it it says p72, its a GSR
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yeah thats the way to go because the type r and gsr in japan both say b18c
  6. badassgixxer
    maryland
    thanks that helps it says pr3 .i just wanted to make sure i dident get screwed .
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    That's not a 100% way to identify them as the B16A also has PR3 stamps, but that's because the head is basically the same, which would also explain the years being different, the bare head was probably produced earlier than the car.
  8. eg6sir
    without ripping open the motor and checking everything its as close as he's gonna get to knowing.. unless he wants to take off teh exhaust manifold and look for the factory port job
  9. badassgixxer
    maryland
    what would i be looking for when i pull it off.i will be pullong it off soon to put the turbo on it.
  10. xj0hnx
    C.C.TX.
    True. Chances are it is what is, what I said was more for just general info.
  11. xj0hnx
    C.C.TX.
    You'd be looking for soemthing that you probably wouldn't be able to see anyway, a light factory polish. I wouldn't worry about it.
  12. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    if its an itr motor why are you gonna put a turbo on it?
  13. AHHVTEC
    Alabama
    im guessing more power
  14. JDMB20Coupe
    Chester, VA
    wouldnt youd be better off with a super charger
  15. AHHVTEC
    Alabama
    boost is boost
  16. JDMB20Coupe
    Chester, VA
    no its not turbo boost hits at one time super chargers are more constant boost
  17. LightWeightChamp
    LightWeightChamp Honda FTW!
    MN
    but a b16a isnt stamped on a b18c :D
    unless the previous owner took a jdm gsr and put a b16 head on, this is a real type r
    and b16a and b18c-r ARE THE SAME head, but the type r comes with a factory port on the intake side. internals are different, like dual valve springs in a type r, and different cams.
  18. LightWeightChamp
    MN
    i thought it was only on the intake side???
  19. eg6sir
    there is a factory port and polish on the exhaust and a porting job on the intake side of the head
    2 people like this.
  20. LightWeightChamp
    MN
    ahhh.. gotchya +1 for good info
