How to tell on ECU what OBD that it is.
Discussion in 'ECU's, Electronics, and Tuning' started by 95hatchcx, Apr 1, 2004.
  1. 95hatchcx
    95hatchcx Member
    The reason i am asking is because i received an OBD1 B18ls
    they sent me a pr4, that won't work will it?
  2. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    according to the REFRENCE section on this site that is either odb0 or odb2 ecu for the ls
  3. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    how many plugs receptacles does it have?
    -2 plug receptacles mean it's OBD 0
    -3 mean it's OBD 1
    -4 would ean OBD II
  4. LOS222
    LOS222 Member
    wrong. You cannot tell if it's obd1 or obd 2 by how many plug receptacles it has. I currently am running a JDM obd1 p13 ecu in my accord and it has 4 plug receptacles. Can't help you w/ the obd0 though.
  5. Slammed90Lude
    milford, PA
    ok, a PR4 that is obd 0 WILL have two plugs and an OBD I PR4 will have three plugs- how's that?
  6. 95hatchcx
    95hatchcx Member
    i have a PR4 that is two plugs and on that is 3 plugs
    it says in the reference section that a PR4 is either OBD0 or OBD1
  7. Slammed90Lude
    milford, PA
    I was TRYING to tell this dude that if his PR4 was OBD I it would have three plugs, sorta like this:
    but i wouldn't know anything about that would I? considering this ECU is sitting on my dresser
  8. 95hatchcx
    95hatchcx Member
    so a 3 plug PR4 is obd1?
    they don't post one as obd1 in the reference
  9. Slammed90Lude
    milford, PA
    yeah i know- but that I bought that PR4 up there with three plugs and it ran an OBD I motor in my buddies hatch
  10. 95hatchcx
    95hatchcx Member
    hmotorsonline sent me a PR4 with my B18b ls obd 1 and i wasn't sure if it would run it or not
  11. Slammed90Lude
    milford, PA
    well does it look just like the picture of the ecu up there? because if so you shouldn't have a problem
  12. pissedoffsol
  13. Projectzc
    Projectzc Senior Member
    I love the back and forth I think this I think that. Then one simple link solves it all. The power the the internet!
  14. LOS222
    LOS222 Member
    yeah good post pissedoffsol. I didn't mean for you to take it personally slammedlude, my appologies. I ran into this same question awhile back and didn't want him to have the same problems.
  15. E_SolSi
  16. katman
    katman Member
    PASADENA, CALIFORNIA
    Honda made 3 OBD1 LS ecu's all of which have the same programming:
    PR4 (which was also the same part number used for OBD-0 LS ecu's too)
    P74
    P75
    Just look at the ecu plugs (as seen in E_SolSi's image) to distinguish an ecu's OBD type.
  17. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    :werd: I WAS going to post up that E has a good pic of the odb's
