how to wire up the Vtec oil pressure
Discussion in 'HYBRID -> ED-EF / DA' started by allaboutdaz, Nov 20, 2004.
  1. allaboutdaz
    allaboutdaz Junior Member
    hello guys
    i am trying to finish up the wiring on my crx that i have just installed a B16
    but i am having problems with the vtec wiring
    there are 2 wires on the vtec oil pressure
    which one goes to the ecu?? and where does the other one go??
    i have been trying and when i wire it up the car turns off and doesnt go back on till i unplug it
    can you guys help????????
  2. brian11to1
    brian11to1 Senior Member
  3. allaboutdaz
    but i wated to know where do i connect the other wire from the vtev oil pressure plug??
    do i just ground it??
    because that what i did and as soon as i grounded the wire the engine would die
  4. brian11to1
  5. allaboutdaz
    yes i did but it only tells me where one of the wires goes and not the other one
    there are 2 on the Vtec oil pressure sensor and one goes to the ecu and the other where??
  6. brian11to1
  7. projekteg
    projekteg Senior Member
    blue wire to pin d6, black wire to CHASSIS ground, not engine ground ;)
