HOW TO WIRE VTEC
Discussion in 'Swap Articles' started by wildbillhatchbac, Dec 19, 2002.
  1. wildbillhatchbac
    wildbillhatchbac the OG VIP
    1. Disconnect the 1P connector from the VTEC solenoid
    valve.
    2. Measure resistance between the terminal and body
    ground.
    Resistance: approx 14—30 ohms
    3.If the resistance is within specifications, remove the
    VTEC solenoid valve from the cylinder head, and
    check the VTEC solenoid valve filter for clogging.
    • If there is clogging, replace the engine oil filter and
    the engine oil.
    4. If the filter is not clogged, push the VTEC solenoid
    valve with your finger and check its movement.
    • If VTEC solenoid valve is normal, check the engine
    oil pressure.
  2. wildbillhatchbac
    hehe somebody got robbed . . . no i'm not browsin HS during honda training ;)
