how would i get the paint off rims??
Discussion in 'Body / Exterior / Interior / Cosmetics' started by fosach1, Oct 12, 2008.
  1. fosach1
    fosach1 New Member
    riverside
    well turns out i got a pair of si rims my friends wants painted with car paint....but he has painted it many times with spraypaint about 6-8 times so how would i go about taking all these layers of paint ....???
  2. MthaFuknGreen
    Lodi, CA
    sand paper.
  3. eg6sir
    dont listen to this guy..
    paint stripper
  4. MthaFuknGreen
    Lodi, CA
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the best you can get it will take it all off in about 2 min
  6. AlterEgo
    AlterEgo When one ego isn't enough
    Nicaragua
    Thats going to strip off the clear coat on the rim too. But so will sand paper. I'd take it to a car wash with a high pressure sprayer and try to blast off the spray paint. If the guy didn't prep the wheels before painting them it'll come right off.
    Other than that, chemical stripper or soda blast them. Try to stay away from sand blasting, it'll chew up the aluminum.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    word..aircraft stripper is the shit
  8. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    4 real...Jet aircraft stripper. Availiable @ autozone/advance/parts store
  9. AlterEgo
    Nicaragua
    Also going to eat at the aluminum. Beware.
  10. SlushboxTeggy
    NJ to MA to CA
    Single mother in a can. Just be sure to clean all of it off when you're done. Then prep the wheels for paint this time.
  11. MazdaAspec
    MazdaAspec /\ IDIOT ALERT /\
    North Dakota
    that is the way to do it but if you want it painter or anything after that, I recommend sand blasted and then powder coated.
  12. 97hatch
    97hatch ?
    Anderson IN
    aircraft stripper and prep and paint. I did my g/f rims this way with base clear about 2 years ago and they still looks good and its her daily drives it in the snow and all
  13. sevenhillsbilly
    sevenhillsbilly New Member
    why dnt you go get em powdercoated instead of painted it will last for alot longer
  14. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    coming from a guy who has painted rims then decided it was a bad idea......
    paint stripper + Pressure washer x 3 passes = allumium
  15. civicmulisha
    civicmulisha New Member
    las vegas
    buy the aircraft remover thats wat i did and then sanded them with 400 grit sand paper then went to a 600 grit and then bought duplicolor wheel paint and mine turned out great and make sure u primer them and dont use the aircraft remover on the plastic center caps it will eat the plastic ohh yeah and get duplicolor clear coat use all of there product and ur wheels will come out great
