Quoted post[/post]]
Do a compression check. Bent valves will = shitty compression.
Any check engine lights? Oxygen sensor in good shape? Vacuum lines hooked up right? Correct fuel pressure? Proper ECU? NOT chipped by a hill billy? Correct injectors? Tuned up with good plugs at a proper gap and good wires? Cap and rotor in good shape? Timing correct? There are LOTS of reasons a motor will run really rich. Missing a spark pretty often will cause gas to mix into the oil. Then again way too much gas will drown out a spark plug, so one problem could be causing the other.
I guess I need more info is what I'm saying.
Quoted post[/post]]
did you check your cam timing VIA marks on the cam gears / crank? maybe it slipped a tooth. bent valves shouldnt cause gas to mix with oil, bad rings would do that.
Quoted post[/post]]
Quoted post[/post]]
Yeah, we checked the Cam marks this wekeend and they seemed to be lined at TDC. The reason why i think it might be the bent valves is bc people say that if the valves are bent, it would allow gas to flood the combustion chamber and therefore, leak down to. ALso, people say that when an engine is runnign rough and seems to chug at intervals instead of a running at a nice constant tone, then it might be that the valves are bad. Are these legit reasons for me to believe that I have bent valveS?
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
a quick way to find out if the valves are bad is to do a compression test and or leakdown, you will know right away if there is a problem. one or more cylinders will be way low compared to the rest. compression test is the fastest and easiest way though. go rent a compression tester at autozone if you dont have one.
