hows this for a setup? ( d16a6 )
Discussion in 'HYBRID -> ED-EF / DA' started by lilsicsol, Aug 16, 2009.
  1. lilsicsol
    lilsicsol i lOve my Ef sedaN..
    brooklyn...
    whats up fellas how you all doing...
    i have a 89 zc motor that spun a bearing
    and in a few days im going 2 pick up a d16a6
    my idea for my set is
    d16a6 block
    zc dome pistons
    and
    a d16y8 head...
    those this sound good?
    i know when you put a y8 head on a d16a6 block
    the comp goes up ..
    but how much more will it be with the zc pistons?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i do not think you will be able to run that setup..i think the pistons are going to be too tall and crash valves...but im not positive
  3. lilsicsol
    brooklyn...
    i was thinking the same...
    just wanted to know if enii 1 had done this.....
    think ii might just do the pistons and keep the stock head...
    enii more input???
  4. blackdahlia6
    blackdahlia6 New Member
    any...a-n-y. although it may be pronounces "en-ii" this is not the correct spelling.
    todays lesson brought to you by, the letter J. as is "Jackass why cant you spell any?"
  5. iheartmycivics
    iheartmycivics New Member
    1 person likes this.
  6. lilsicsol
    brooklyn...
    oow shit feel better about your self?
    brought to you by... me...
    jump off ma dick....
  7. lilsicsol
    brooklyn...
  8. jlicrx
    jlicrx Senior Member
    Colorado Springs
    depending on which head gasket you use, i get 11.6 to 12.46 for the Z6 head and 12.3 to 13.08 for the Y8 head
    piston to deck height with the DOHC ZC PM7/P29 pistons is 0.040"
  9. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    You could try this, its a no-tec setup but who needs vtec?
    D16a6 block (75mm bore)
    D16a6 crank
    D16a6/ LS rods modified to fit crank (137mm)
    D16a1 P29 pistons
    D16a6/b2/b7 head (0.005 milled for resurfacing)
    D15b7/a6 head gasket (0.048in)
    Block deck milled (0.020 in)
    11.50:1 compression ratio W/ 1590cc dis
    0.019 piston-to-deck height
    1.52:1 rod / stroke ratio
