HPS Intakes, Air Intake Hoses & Silicone Connectors
Discussion in 'CorSport' started by CorSport, Jan 28, 2011.
  1. CorSport
    CorSport Member
    Find HPS Parts for your car here
    [​IMG] [​IMG] [​IMG]
    HPS All Cars Category
    Click here to see these products in our catalog and check out the most current pricing.
    HPS High Temp Reinforced Silicone Hoses
    HPS Silicone Hose features 4-ply reinforced high temperature material, for which meet or exceed SAEJ20 Standard. HPS Silicon Hoses are used by professionals in industries such as high performance racing vehicles, commercial truck and bus, Marine, agricultural and off highway vehicles, turbo diesel, food and beverage, and general manufacturing industries.
    HPS silicone hoses are available in straight coupler, 1 ft tube, 3 ft tube, Charge Air Cooler Hose (CAC), hump coupler, reducer coupler hose, 45 Degree Elbow Coupler and 45 Degree Elbow Reducer, 90 Degree Elbow Coupling and 90 Degree Reducing Elbow. HPS also carry the performance silicone vacuum hoses as well. HPS silicon hoses are available in both standard inches and hard-to-find Metric sizes. In order to meet the high demand and shorten the turnaround time, up to 90% of HPS silicone hoses are instock and ready to ship or pickup from HPS store.
    Features
    HPS silicone hoses are made of 4-ply reinforced and knitted premium polyester fabric with high temperature silicone rubber, engineered for extreme temperature and various pressure ranges where high performance levels are required.
    Technical Specification
    Temperature Range:- 65 deg. F to + 350 deg. F (177 deg. C)
    Color: Black / Blue
    Reinforced Layer: 4-ply
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
    Huge selection of intakes, hoses and couplers
    CorSport: HPS
  3. CorSport
    CorSport Member
    HPS intakes and hoses at CorSport.
  4. CorSport
    CorSport Member
  5. CorSport
    CorSport Member
  6. CorSport
    CorSport Member
  7. CorSport
    CorSport Member
    HPS available at CorSport!
  8. CorSport
    CorSport Member
    94-01 Acura Integra HPS Silicone Radiator Hoses Kit (Red)
    [​IMG][​IMG][​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    PS High Temperature Reinforced Performance Silicone Radiator Hoses Kit
    The HPS Radiator hose kits are designed to replace OEM rubber hoses. This hose kit can be used for both motorsports and daily driving use. HPS Radiator hoses are made from multi-ply premium grade silicone and reinforced with high-quality polyester for which reduces the risk of component failure and enables higher temperature and pressure to be maintained with complete confidence.
    Technical Specifications
    3-Ply Reinforced
    Silicone hose is NOT compatible with fuel or oil.
    CorSport USA.
