Huge Bseries Linkage Problem
Discussion in 'General Tech and Maintenance' started by slammedb18acivic, Feb 17, 2003.
  1. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    i have a 93 ls in my 90 hatch. im going through my second linkage. this linkage from HCP. My problem is i cant get all my gears. i have 1st,2nd,3rd,4th no reverse no 5th. is this because i might have put the linkage together wrong. ive played w/ it a few times and this seems like the only way it even bolts up. please help this is making me not get my car back on the road.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    sound like it could be too short,or hitting something underneath.Have someone try it while you look under the car at it.
  3. solblu
    solblu Senior Member
    Ricer
    Make sure it's not the tranny, shift it through all the gears with a punch or something. It twists to get to 5th and reverse, the only thing that would be hitting would be the actual shifter.
  4. TopNotchRacer
    TopNotchRacer Junior Member
    if its a B20 you need to put a Integra Iinkage if not Put some Old in your Tranny.
  5. solblu
    Ricer
    Why would a B20 be any different. On the outside it's the same as a LS block.
  6. slammedb18acivic
    pa
    thanks fellas, got it wrking . the way i got the linkage sent to me wasnt put together for my car right at all. i just messed around alittle and got all my gears ! thanks again
