huge garage sale 56k beware
SoSlo
Member
UPDATED
JDM B16A short block odb0(dissasembled-cleaned-reassembled)_$125
JDM B16A short block obd1 (complete ready for a head)________$125
b18a1 head with all valvetrain______________________________$35
2000 gsr intake manifold just missing tb and idle control valve____$30
jdm b18c crank (need to be polished has 1 spun rod bearing)_____$50
b series oil pump(used)____________________________________$15
ls water pump(used)_______________________________________$10
ls timing belt(used)________________________________________$10
b series oil pickup_________________________________________$15
b series coolant tube with thermostat housing(used)_____________$20
b series water pump(used) _________________________________$10
b series idler pulley(used)___________________________________$5
b16 tranny brace_________________________________________$5
obd2 crank angle sensor___________________________________$15
obd 2 timingbelt crank pulley(chipped)________________________$5
obd 1 timingbelt crank pulley_______________________________$15
vx (13/16) brake master cylinder____________________________$5
ls head bolts_____________________________________________$15
gsr head bolts___________________________________________$15
obd1 gsr injectors________________________________________$15
obd 1 gsr distributer_______________________________________$75
gsr crank pulley___________________________________________$25
gsr flywheel______________________________________________$10
4 gsr pistons on rods______________________________________$35
4 b16 rods(rods scratched but usable)________________________$10
3 usdm gsr pistons with wrist pins____________________________$10
2 jdm gsr pistons with wrist pins______________________________$5
blue eg steering wheel______________________________________$10
drive side eg manual mirror___________________________________$5
srs computer_______________________________________________$15
turn signal and wiper switches_________________________________$15
complete engine bay fuse box_________________________________$20
empty ecu case_____________________________________________$10
ls crank case breather box____________________________________$10
gsr crank case breather box___________________________________$10
egr vacume control box______________________________________$15
gsr engine header bracket____________________________________$5
black charcole box___________________________________________$5
b series msd modified dist cap with coil wire______________________$20
gsr fuel pump_______________________________________________$10
5 bolt turbo exaust flange_____________________________________$10
gsr throttle cable with bracket_________________________________$5
2.5"-3" turbo coupler________________________________________$5
2.5" t-clamp_______________________________________________$5
3" t-clamp_________________________________________________$5
92-95 oem headlights with turn signals, one pracket broken________$10
obd1 coolant temp sensor(block)______________________________$5
ls intake manifold bracket_____________________________________$5
b series coolant thermostat housing and tube____________________$15
4 oem b series wrist pin______________________________________$5
new pics comming soon
everything is OBO
i am paypal certified
hit me up at smmccurdy@hotmail.com
dude i really want the blue eg steering wheel, obd1 crank timing pulley, msd cap, charcoal canister, and the idler pulley. could you ship to louisiana? let me know how much it would cost to ship and if you accept paypal. thanks
ok, i don't need the canister or the tensioner, but i still want the dizzy cover, the steering wheel, and the gear. would you mind sending me a paypal payment request with the adjusted price? smackedhatch@yahoo.com thanks bro!
b18a1 head with all valvetrain_________________________ _____$35
Still got these three? If so I live in Portland. Don't have a paypal account, but I could probably get one. thanx
