hybrid setup
Discussion in 'Engine Building' started by typesiracing, Jan 20, 2004.
  1. typesiracing
    typesiracing Senior Member
    ny
    i already have all these parts so cost effecetiveness is not an issue......i have a gsr block with gsr rods, crank and type r pistons....my plans (i have it on stand already) is to remove the gsr crank and replace with an ls crank...so it will be ls crank, gsr rods and type r pistons in a gsr block, i also have a b16 head. my only concern would be clearences. does anyone know if this will work?
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    I beleive you'd have to use Ls rods.
  3. typesiracing
    ny
    ok thats the kind of answer i was looking for...but the gsr rods are stronger i believe?
  4. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    why are you taking out a 1.8l crank for a 1.8l crank?
  5. typesiracing
    ny
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I would keep the gsr crank, I honestly don't think the extra work is really worth the ~34cc's.
  7. typesiracing
    ny
    i hear ya but i already have to rebuild and it's all apart now so i mind as well just do it now........so does anyone dissagree and can say that the gsr rods will work?
  8. kyleirwin
    kyleirwin Retired OG
    Vegas
    gsr rods are too long, if you want to use the ls crank you're going to have to use ls rods.
  9. typesiracing
    ny
    gotcha! i know the ls rods are 137mm and the gsr rods are 137.9 but i guess that enough. thanks for the help!
  10. phunky.buddha
    Dallas / Fort Worth, TX
    Want some Eagle rods for your LS stroke? I've got a set to sell... look on my web page.
  11. typesiracing
    ny
    i know you guys are telling me that i have to use the ls rods with the ls crank but for ha ha's i slapped together the ls crank with gsr rods and type r pistons and everything is working....is it the head clearance that is the problem? because even that seems to be damn close to the same.....not that i'm doubting, i just want to understand why and know that you are sure....thanks again
  12. ek9r
    ek9r Senior Member
    Long Island NY
    you will have to rebuild the whole thing if you turn that key and rev it up. listen to theese guys, they know what their talking about.
  13. typesiracing
    ny
    ok...gotcha...just wanted to be sure....thanks again.
  14. cws13
    cws13 Senior Member
    Athens,GA
    Turning it over by hand will not represent the clearences once the motor is in full swing. Stretch.
  15. lsvtecguy
    lsvtecguy Junior Member
    weird cuz I have an LSvtec, using GSR rods, with Type R pistons, and I have revved out to 8600 all the time, and my motor still runs like a champ, and also the occasional 75 shot nitrous. I am not saying any of you guys are wrong, but I am just saying that so far I haven't had a problem with the GSR rods in the LS block.
  16. driver1
    driver1 Senior Member
    well its not the gsr rods in the ls block that is the problem its using the combination of the gsr ls crank witht he gsr rods....they arer to long and will create head clearance issues and more importantly piston to valve clearance issues. If it creates enough of a clearance issue then when u start the pistons can hit the valves and bend them.
  17. lsvtecguy
    hmmm.. I am sorta confused then. Why would the GRS rods on the LS block with the LS crank, not be a problem, but the GSR rods with the ls crank in the GSR block, be a problem. I thought the only difference between the two was that the GSR had oil squiters, and the gsr girdle. I am actually in question now. Action motorsport told me the GSR rods would be better if I had to choose between the two. and my lsvtec has been running fine. I am sorta worried now, if the clearance issues are that serious. and plus I don't have the money for eagle rods or anything.
  18. driver1
    the gsr rods are longer than the ls rods....so when u put them on the ls crank u create a longer stroke which will make the pistons go higher in the block...therefor possibly creating a clearance issue
  19. lsvtecguy
    o.k. I understand that. like I got that through my head, but is there a lesser of a danger in the LS block than in the GSR block, that is what I was really trying ask. cuz like I said my motor has been running strong, and one of the replies, I think said that right when you start up your motor with this setup, your motor would fry, so I am wondering if there was a difference in hazard of running those rods in the LS block. Cuz so far I have had no issues of daily 8600 on ramp power shifts, sometimes with nitrous. and I am hearing no noises or anything. using a b-16 head, not milled at all.
  20. driver1
    no the block shouldnt make a diferrence as far as that goes as long as your using the correct rod/crank combination...and for that matter if your car is pulling 8600rpm smoothly with good power than i cant assume that u have any real problems, if something was to happen it eould have been right away
